  • You must configure the required SPBM and IS-IS infrastructure.
  • You must log on to the route-map configuration mode in the CLI.
Use this procedure to configure the IS-IS external metric-type by using a route-map for any of the following cases:
  • accept a remote IS-IS route with the help of IS-IS accept policies
  • redistribute routes from other protocols into IS-IS
Caution
Caution
To use IS-IS Route Tagging on GRT IS-IS routes, you must also configure the metric-type as external. If you want to use IS-IS tags on GRT as internal routes, all Fabric nodes must be above a minimum software version. Any switch in the SPB Fabric that runs earlier software versions triggers an exception if you use metric type internal. To ensure this does not occur, if you attempt to configure a tag and the metric-type is not external, the switch reminds you to upgrade the software on all devices. You must ensure all devices in the network run the minimum required software.
  1. Enter Route-Map Configuration mode:
    enable
    configure terminal
    route-map WORD<1-64> <1-65535>
  2. Configure the IS-IS metric type:
    set metric-type-isis {any|internal|external}
  3. Permit the route policy action:
    permit
  4. Enable the route policy
    enable
Configure the metric type for IS-IS routes:
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# route-map ro1 10
Switch:1(route-map)# set metric-type-isis internal
Switch:1(route-map)# permit
Switch:1(route-map)# enable
Set metric type for IS-IS routes in accept policies:
Switch:1> enable
Switch:1(route-map)# exit
Switch:1(config)# router isis
Switch:1(config-isis)# accept route-map ro1
Switch:1(config-isis)# exit
Switch:1(config)# isis apply accept
Set metric type to redistribute routes from other protocols into IS-IS:
Switch:1> enable
Switch:1(route-map)# match metric-type-isis internal
Switch:1(config-isis)# redistribute bgp route-map ro1
Switch:1(config)# isis apply redistribute
The following table defines parameters for the set metric-type-isis command.
Variable
Value
Specifies the IS-IS metric type:
  • internal – permits or denies routes that are internal to the IS-IS domain.
  • external – permits or denies routes that originate from an external routing protocol domain.
  • any – permits or denies both internal routes as well as external routes.
